Batch Processing of chromatograms not measured by sequence
This section allows you to vote for new features that may be implemented into Clarity.
  • Vote for the feature to increase its priority and discuss how it should be implemented.
  • How to vote? Just log in to your forum account and the voting options will appear.
  • If you have not found your desired feature here, create a new thread for it.
  • You will not be able to create the poll yourself, but after the checking of the suggestion, we will create the poll for you.
We do take this poll seriously, however it is not the only source of priorities for the development.
Do you need to reprocess various chromatograms to create standards and calibrated chromatograms?
No
0
No votes
Yes
3
100%
Total votes: 3
thoblerone
Post by thoblerone »
I would like to be able to set up a sequence of arbitrary files from different folders to create my calibration and analysis data.
Unfortunatly batch reprocessing works just within a sequence which has been measured before as the File Name column eventually holding place holders is just used during data acquisition. During batch processing an internal column holding the actual file name is used. But this one is not available in the user interface.
Hopefully in a future version we can decide to pick some chromatograms, set them as calibration, pick some other and treat them as samples and just run a single batch process to get my results.
Thomas Blenkers
Re: Batch Processing
In Clarity version 6.0.0. 295 the sequence was improved so that the sample type (standard/unknown) and calibration level could be changed for sequence reprocess. Still, the reprocess is possible only for chromatograms which were previously acquired by the sequence.
Further amendmends are planned for future versions
