I upgraded my version of Win10x64 from 1903 to 2004 and the Colibrick device no longer loads at system startup. I get the following error message:
"The installation of this device is forbidden by system policy. Contact your system administrator."
From Events in Device Manager:
Device blocked (oem30.inf)
Device USB\VID_DAAE&PID_EAD7\3402 had its configuration blocked by policy.
Driver Name: oem30.inf
Class Guid: {3101cb48-a8aa-4edd-a1be-d4778c138a68}
Driver Date: 07/14/2010
Driver Version: 3.3.0.0
Driver Provider: DataApex
Driver Section: DriverInstall.NT
Driver Rank: 0xFF0001
Matching Device Id: USB\VID_DAAE&PID_EAD7
Outranked Drivers:
Device Updated: false
Status: 0xC0000361
Parent Device: USB\ROOT_HUB30\4&4fe1150&0&0
Does anyone have a fix other than rolling back the Win10 update?
Colibrick Not Loaded at Win10 Startup
Paul Zietz
Re: Colibrick Not Loaded at Win10 Startup
Dear Paul,
This is actually for the very first time I see such error. I've been running Windows 10 version 2004 for more than two months and haven't faced such issue so far,,,
Could you let me know serial number of your Colibrick (printed in upper right corner on the rear side) and serial number of your Clarity station? How to find serial number of Clarity station is described in this topic: https://www.dataapex.com/documentation/ ... -about.htm?
Please send us the Clarity diagnostic files (as listed below) for analysis.
C:\Clarity\CFG\clarity.cfg
C:\Clarity\CFG\clarity.dsk
C:\Clarity\CFG\systeminfo.txt
C:\Clarity\CFG\Debug_Logs\badtrace.txt
C:\Clarity\CFG\Debug_Logs\install.log
C:\Clarity\CFG\Debug_Logs\install.move.log
Please send these files to support@dataapex.com and we will inspect them and will try to come up with some solution for you.
Jaroslav Kana
Jaroslav Kana
Jaroslav Kana
Colibrick serial number: 3402
Clarity station serial number: 011-57569+064/01
The Clarity station is actually Elemental Analysis Software v. 7.1.0.156 obtained from Costech Analytical Technologies, Inc.
I am unable to send any of the files you requested. I rolled back my installation of Windows10 2004 to the earlier version so those files are gone. Anyway, the problem is fixed for now. Thanks for your reply.
Paul Zietz
I ended up wiping the HP computer and re-installing Windows 10. After doing that the problem with Clarity and Colibrick driver installation went away.
