Hi!
We noted that in the Clarity version 3.0.2.244 the temporary files generated with the snapshot are automatically saved and at the end of the analysis the final file doesn't replace the snapshot files.
In this case we have got more files for any run. How can we do to avoid the files creation? Are there any setting?
Thank you,
Michela & Flavia
Snapshot files are automatically saved
Michela Gasperini
Re: Snapshot files are automatically saved
Dear Michela,
the described behavior is really a bug that emerges in version 3.0.2.244 when you use the %n variable in the file name. The variable is not behaving correctly, so even taking a snapshot increments it. We have found the bug shortly after the release of the 3.0.2.244, and it will be repaired in the next release version (which is now in the process of testing, the bug is already repaired).
