When creating a new sequence, each row should be correctly filled in. Clarity at the moment helps with that by pre-filling some of the fields by default values taken from the previous row, but there is still a plenty of things the analyst should take care about (the frequency and position of control samples etc.). These are the things a sequence wizard may help you with.
Much greater use of the wizard would be appropriate if the calibration bracketing would be also implemented. To learn more about the calibration bracketing or vote for the faster implementation of this feature, please visit this thread.
Do you want DataApex to include this feature? Vote in the poll and discuss the feature in this thread to fasten the process!
Internal issue tracking ID: 30179
Wizard for new sequence
Reason: issue tracking ID
