Command line seq_import
pault
Post by pault »
Dear coleagues.
I'm testing command line parameters with demo Clarity, espacialy seq_import. My command line is following:
D:\Programs\Clarity_Demo_BETA\Clarity.exe seq_import=I:\M-0045\Sekvence\111.txt
Import of txt file to the Clarity sequence table works. But I have problem with mapping of some fields like Injection volume, open, export TXT. The imported file 111.txt is attached. First row of my imported sequence txt file is header. TAB is Delimiter. If I import this file manually throught Sequence menu, it is imported and mapped correctly. Is it possible by command line to append imported sequence to current sequence in Clarity?
111.txt
(702 Bytes) Downloaded 426 times
Tomas Paul | Clarity 3.0.2.244 | 3x GC + 6x FID (3 dual systems)
Re: Command line seq_import
For appending the imported lines to active sequence please use another command line parameter (Clarity version 2.7.3 and higher)
seq_import_append
description: Imports the specified *.txt file as a sequence. Current sequence is appended with lines from the imported file, Sequence window is opened. Can be performed when the sequence is running. Sequence Options dialog is never opened after command line import. Import settings are the same as the last saved ones during manual import.
syntax: seq_import_append=PATH\FILENAME
possible values: A valid path and filename.
implicit value: None.
example: clarity.exe seq_import_append=c:\tmp\seq.txt
pault
Post by pault »
Dear Ivan,
I have tested seq_import_append. It works, but I have still problem with mapping (assing) some fields. Incorrect values are imported to these fields: Injection volume (0), Open (Yes), Export TXT (No). I've stored in my txt file prepared for command line import these values: Injection volume (2), Open (No), Export TXT (Yes). Do you have any idea what I am doing wrong? I am testing these line commands on demo version of Clarity 2.7.3.498.
Best regards, Tomas
This seems to be a bug in Clarity (ID 31784). I will let you know, when a fix will be available
The bug was fixed in version 2.8.2.593
pault
Post by pault »
Thank you Ivan,
I'm gonna test it in new year. Beacause I work in PC network, my program will generate one txt sequence file and one batch file (*.bat) with import instruction. User then will launch the batch file on the instrumental PC.
Tomas
