integration copying issue
labjohnstown
Post by labjohnstown »
I'm not 100% sure how to explain this. I have two FID's on my GCs and I have two different methods as they are different columns. When I calibrate the second column, I cannot copy from chromatogram or copy from anywhere for that matter into the sencond FID. Yes I do have it selected but in my method it will always go into the first FID but that is not the FID I am using in the method. So I basically have to clip the parameters and input them all manually into the second FID. I'm not sure if this makes sense. I know I had asked Ivan about this but he said that it is not something that can be done at this time.
Tracey Geneau
