Navigation / Explorer bar
Would you find it useful to have explorer bar (such as Chromeleon has) in the Instrument window?
No
Yes
5
100%
Total votes: 5
eddielepew
Post by eddielepew »
Would like to see an explorer side bar? Like the one in Chromeleon and OpenLab. This would enable direct access to methods and data. Double clicking on data could open up the chromatogram window, double clicking a method could open the method to edit it. Sequences could be double clicked on to open up the sequence table to run or to batch reprocess.
Reason: I added poll.
Lee Weatherill
Marek Pesta
Re: Navigation / Explorer bar
Post by Marek Pesta »
Hi Lee,
thank you for submitting your suggestion. It is being tracked under Internal issue tracking ID: 85651.
Kind regards,
Marek
Marek Pesta
LWaugh
Post by LWaugh »
eddielepew wrote:Would like to see an explorer side bar? Like the one in Chromeleon and OpenLab. This would enable direct access to methods and data. Double clicking on data could open up the chromatogram window, double clicking a method could open the method to edit it. Sequences could be double clicked on to open up the sequence table to run or to batch reprocess.
I would also like to see this. It would make navigating around the software much easier.
Louis Waugh
