IMPLEMENTED - Export also auxiliary signals
Locked
Do you need export of auxiliary signals implemented in Clarity?
Poll ended at Fri Apr 17, 2015 2:41 pm
Yes.
No.
Total votes: 0
AKLaemmerhofer
Post by AKLaemmerhofer »
Dear Team from DataApex,
We are using a Shimadzu LC10AS-System and discovered strange and not reproducible peaks.
Therefore we then informed us, that there is the possibility to record also the pump-pressure as auxiliary signal.
It was very revealing. But now, I'd like to make a diagramm, where I now need also the raw data from the auxiliary signal 'pressure'.
Until now I use the export-data function for exporting the data into Excel. It works splendid and bought me a lot of time...
Maybe it's possible to include this Export-to-Excel-function also for the auxiliary signals like the pressure?
Stefan
ISS-28093
Zdenek Telicka
Re: Export also auxiliary signals
Post by Zdenek Telicka »
Dear Stefan and all,
Exporting of Auxilliary signals to .TXT file has been implemented in the latest Clarity 7.3. You can update directly from your station or wwwdataapex.com/downloads.
Zdenek Telicka
Locked
