IMPLEMENTED - Calculation input box
Locked
Would you find a user-editable field(s) in the Chromatogram window useful?
Yes, could definitely use more than one in a single chromatogram.
2
100%
Yes, one such field per chromatogram would be enough.
No, I do not need this feature.
Total votes: 2
Lab-Comp
Post by Lab-Comp »
We would like to ask one or two input box for calculation.
Location of the input box: chromatogram window.
Reason of the box: this value in the box can be used in user made column calculation.
For example: The customer have to calculate with the density. This value can be different in every sample, and they don’t want to modify the calculation formula in the user made column.
Internal issue tracking ID: 62043
Peter Balogh
Zdenek Telicka
Re: Calculation input box
Post by Zdenek Telicka »
We have introduced User Variables in Method, Single Run, Sequence table and Chromatograms in Clarity 7.0. Users are now able to use those custom variables in Results - User Columns of the measured chromatograms. See the What is new in Clarity 7.0.
Zdenek Telicka
Locked
