It is useful to be able to check the peak ID as the chromatogram is running
Internal issue tracking ID: 17296
IMPLEMETED - PDA Isoplot to be available in Data Acquisition in Real Time
Dr Stuart Jones
Re: PDA Isoplot to be available in Data Acquisition in Real Time
Generally it is possible to display received PDA spectra in realtime, although it imposes much greater requirements on fast data processing than displaying common detector signal. We will implement this feature in some future version, but the priority of this task is not high, as we don't consider it really necessary for everyday use.
Jiri Kuntos
