Navigation / Explorer bar
- Vote for the feature to increase its priority and discuss how it should be implemented.
- How to vote? Just log in to your forum account and the voting options will appear.
- If you have not found your desired feature here, create a new thread for it.
- You will not be able to create the poll yourself, but after the checking of the suggestion, we will create the poll for you.
Would like to see an explorer side bar? Like the one in Chromeleon and OpenLab. This would enable direct access to methods and data. Double clicking on data could open up the chromatogram window, double clicking a method could open the method to edit it. Sequences could be double clicked on to open up the sequence table to run or to batch reprocess.
Reason: I added poll.
Lee Weatherill
Re: Navigation / Explorer bar
Hi Lee,
thank you for submitting your suggestion. It is being tracked under Internal issue tracking ID: 85651.
Kind regards,
Marek
Kind regards,
Marek
Marek Pesta
I would also like to see this. It would make navigating around the software much easier.eddielepew wrote:Would like to see an explorer side bar? Like the one in Chromeleon and OpenLab. This would enable direct access to methods and data. Double clicking on data could open up the chromatogram window, double clicking a method could open the method to edit it. Sequences could be double clicked on to open up the sequence table to run or to batch reprocess.
Louis Waugh
