Page 1 of 2
Default method
Posted: Tue May 05, 2015 12:14 pm
by nkokras
Hello!
How can I change the default method that is loading each type an instrument is opened?
I would like to set some universal parameters, save the "noname" method by a new name (as "default.met") but then, it does not load automatically when I re-open the instrument.
Re: Default method
Posted: Tue May 05, 2015 12:24 pm
Dear Nikolaos,
normally the method which is opened on the Clarity Instrument when the Instrument is opened is the one which was there when the Instrument is closed. The method to be opened is stored in the project used, so if you are changing projects between reopening Clarity Instrument, this may end up in the described behavior.
Also, usage of the LaunchManager utility (or other uses of Clarity command line parameters) may force an Instrument to be opened with set project, but different then default method. Other than that, I do not see a way why this could happen on your station - please send the audit trail file from the day this behavior happened to
support@dataapex.com . The proper audit trail is stored in the C:/Clarity/Log subdirectory, named by corresponding date. If you could perform the test (e.g. changing the method, closing instrument, reopening instrument (or what your procedure is to invoke the behavior)) and send us the audit trail, we can discern the reason of the behavior pretty quick.
Best regards,
Re: Default method
Posted: Tue May 05, 2015 3:29 pm
by nkokras
Indeed, we open a new project each day and ideally, I would like to use the same default method regardless of the daily project. The point is to have a pre-configured method and users of the system can create a daily project but do not need to know about method settings.
Re: Default method
Posted: Tue May 05, 2015 4:02 pm
OK, in such case it is necessary to change the default method that is copied into new projects. The default method is saved in the C:/Clarity/Common subdirectory under the name Default.met , please save your desired template method under the exact same name (using lowercase/uppercase letters where appropriate). This should force the newly created method in the newly created project be already filled in.
Please let us know how it went.
Re: Default method
Posted: Tue May 19, 2015 11:20 am
by nkokras
Thank you for your reply
Our working directories are C:\Clarity\HPLC-1 and C:\Clarity\HPLC-2 (set in the directories option of the program)
I have tried the C:\Clarity\HPLC-1\Common\Default.met and the C:\Clarity\Common\Default.met.
None works
Any ideas?
Re: Default method
Posted: Wed May 20, 2015 7:25 pm
OK, I stand corrected. After some experimenting with the methods, I unfortunately do not have clear solution for your case at the moment.
When a new project is created, no method is copied into it (no method is opened when you first enter such project) as there is no information in the project file which method should be opened (or was opened last time). This also means that the default method name displayed is "noname" and that it is filled by default parameters from the particular control modules code (non-modifiable at user level).
I can only suggest some workarounds at the moment, copying the method from the previous project or another location after the project is created/opened and opening the method for usage.
I have started a suggestion ISS66509 to implement copying of the default.met into the newly created project.
Re: Default method
Posted: Wed May 20, 2015 10:38 pm
by nkokras
Ok, that's too bad indeed for our working routine.
Let's only hope that in the next update there will be a copying of the default.met from the common dir to the current project dir.
Re: Default method
Posted: Thu Jun 04, 2015 11:58 am
by nkokras
Any chance it will make it to 6.1? I do not see it in the changelog so far
Re: Default method
Posted: Fri Jun 05, 2015 9:49 am
No, unfortunately no chance for that. Even at the moment of creating the issue it was past time to include anything in the version, the version was already closed for any new submissions for few weeks.
Re: Default method
Posted: Mon Jun 06, 2016 12:29 pm
by nkokras
Hello, has this issue been resolved in v.7?
