Automatic shutdown on Clarity with Agilent HPLC
Posted: Mon Jun 23, 2014 11:45 am
we are using Clarity on an Agilent HPLC system through the ICF controls.
Since most of of our customers are working overnight with their Agilent HPLCs, due to the high number of samples to be processed in a single run, we need the possibility for Clarity to stop the HPLC (i.e. switching off lamp, pump and thermostat) at the end of the run. ChemStation has a STANDBY option, which is programmed in the sequence parameters for this, and I tried to find out something similar on Clarity but I wasn't able to get the desired effect.
I tried to use the Event tab in the method, with the "shutdown" command but Clarity went stuck after the end of the first sample (probably, using ICF is preventig it to work properly). In the sequence window, I wanted to use the "Run Program" and "Program to run" columns in order to achieve this, but, of course, there wasn't such a program available (at least, I could neither find it, nor I am able to write it down by myself...)
At present, we managed to use a last line in the sequence, calling a fake method (0 mL/min flow rate, no temperature control, 0uL injection) which does part of the job, but, unfortunately, there is no way to switch off the UV lamp, for instance.
Can you somehow please help me with this issue?
