On a couple of my clarity stations, I use the FC GP module to control Bio-Rad 2128 fraction collectors. The fraction collector functions as expected, but occasionally the chromatograms generated by clarity do not show the fraction numbers. The show events check box has no effect when this occurs. Sometimes the times and volumes for the fractions are present in the "FC GP" results tab, even though they are not displayed on the chromatogram. Most often, however, the data is not present in that tab either. It seems as this occurs most often when the run has ended due to the last tube being reached, or if the run is stopped or aborted before finishing. What could be causing this issue?
Fraction collector data
Re: Fraction collector data
Dear Scott,
I do not see any apparent reason for this behaviour, however, I might be able to find some when inspecting the system files. Please, send us the usual diagnostic files, please, so we may look into the matter. The needed files would be:
- c:\clarity\clarity.cfg
- c:\clarity\clarity.dsk
- c:\clarity\systeminfo.txt
- c:\clarity\badtrace.txt and all *.dmp files (may not be present, they are created during some problems only)
- c:\clarity\log\ *.audit for the days the problem appeared
- a chromatogram (*.prm) file that shows the bad behaviour, and, if you have one, a chromatogram that is OK.
- a method (*.met) file used to acquire the chromatogram
