yl clarity sampling frequency setting of yl9120
jaroczajka
Post by jaroczajka »
Dear Sirs,
I have found YL Clarity problem with setting sampling frequency of YL9120 UV detector. It seems every time it keeps only 1Hz value. I cannot change it into other values like 5hz or 10Hz.
Please let me know how to solve it ?
JCzajka
TLab
Jarosław Czajka
Re: yl clarity sampling frequency setting of yl9120
The condition for setting higher sample rates than 1 Hz in YL9120 is, that both signals use the same wavelenght (even if one of them is disabled).
lorylaci
Post by lorylaci »
Dear Ivan,
I am having similar issue. As you can see in the attached picture, my signal looks stepwise at all sample rates exept 1 Hz. I tried all filter settings, setting both channels to the same wavelength, did not work. I attach also the method.
P9 Buturon.met
Method
(61.2 KiB) Downloaded 958 times
Stepwise waveform
Stepwise waveform
Lorantfy Laszlo - Fumoprep Ltd Hungary
YL91xx HPLC-UV-CAD-FLD, YL91xx HPLC-UV, YL6100 GC
Dear Laszlo,
please could you send us the acquired chromatogram to support@dataapex.com? I could not check the method file without corresponding configuration, it is however recorded in the chromatogram.
