Y scale configuration on Clarity Lite
mnertz
Post by mnertz »
Is it possible to configure the Y scale label and units on each channel with Clarity Lite, as it is on Clarity standard. I didn't find a way on the demo version, downloaded for evaluation before buying the right version.
Thanks for the advice.
NERTZ
Re: Y scale configuration on Clarity Lite
it is possible to change the Y-axis label and data units in the Clarity Lite version. To do so, start the Clarity Lite and open the Chromatogram window. Then, use the Display-Properties... command and switch to the Signal Axis tab. On this tab, check the Override Signal Units checkbox and fill in your own Axis Title, Unit Type display and signal Units along with Prefix. Leave the dialog using the OK button.
Anytime the Chromatogram window is opened from then, it will show the customized signal units and signal axis title. Analogically, the time axis could be changed to display the things you want on the Time Axis tab.
