Distance to PC
dani50
Distance to PC
Post by dani50 »
Dear all,
We are dealing for a Clarity station to get data from 2 GCs separated by a
50 meters distance. If I remember well Clarity is prepared to connect
through a 30 cable. Is there any alternative or option to have these 2
instruments connected to the same PC.
Thanks and regards,
Daniel C. Escati
CosmoBio srl
Buenos Aires, Argentina
Phone (5411) 4801-6607
Fax (5411) 4805-2291
mailto:de@cosmobio.com.ar
www.cosmobio.com.ar
Daniel Escati
Distance to PC
Dear Daniel,
there are basically two possibilities
a) we can provide 50 meters long cable
Then it depends on several factors:
- the quality (strength) of the signal from the detector
- how big peaks you would like to measure (the bigger the better)
- the amount of interference from the environment
(generally you can a give it a try and it may work OK)
b) you can use the NetPAD
it is an external A/D converter connected to the PC over LAN (TCP/IP),
the distance of the chromatograph from the PC does not matter at all then
(more information is available at www.dataapex.com/products/netpad.aspx)
with best regards
