A Real Time Chromatogram
yetter
Post by yetter »
Hallo,
If I start the RUN, the Chromatogram is only shown at the end of the RUN. How can one produce the Chromatogram real time?
with regards
Martin Yetter
Martin Yetter
rembert
Post by rembert »
Hi Martin,
observe the main window of your instrument (the instrument window) and click
on the icon which is like a screen. After starting an analysis you can read
"RUNNING" below it. Clicking will open the acquisition window and you will
be able to see your chromatogram developing.
Good luck!
Rembert
Rembert Forche
Jan Hruby
Post by Jan Hruby »
I'd like to add that the Data Acquisition window displays detectors
signal without detection of peaks.
For instant displaying detected peaks you can use the Snapshot command
(from Single Analysis or Data Acquisition windows) anytime. This command
saves and analyses currently acquired data (without termination) into
chromatogram file and this file will automatically be displayed in the
Chromatogram window. Repeated using of Snapshot command saves data into
the same file without any warning message.
Jan Hruby
Jan Hrubý
