HTA 300L Injection volume
thes
Post by thes »
I tried to run a HTA 300L with the Clarity 2.3.0.174 but there is a problem with the sample volume sents to the autosampler.
I make a sequence with 3 runs and 50 µl Inj. Vol. - but an error message occure because the sample volume is to much. I use the AS control menu and click on the From AS button and a sample volume of 500 µl is shown. I tried this with 10 µL in the sequence and the HTA300L injected 100 µL. It looks like the Clarity software is sending an Injection volume with a multiplier of 10.
How can I change that?
Thank you very much in advance.
Hans
HaJo Thes
Dear Hans
It is a bug, it will be fixed in the next build 2.3.0.183.
I will send you an announcement once it will be available on the web.
Thank you for reporting it.
Hans,
Clarity 2.3.0.183 is available for download from our web.
Petr
PS: It was quite a luck, that we were just preparing new update to be released, normaly it takes longer time to get a fixed feature out (due to the time consuming testing).
