Autosampler Control
- Petr Kohutek
- Contact:
Re: Autosampler Control
Nice to see, that the problem disappeared
good luck with using the sampler
Petr
Petr
The sampler is good, but the manual...
Claus
Claus
- Petr Kohutek
- Contact:
The problem was in the autosampler manual or in our control module manual?
If you had any troubles with our manual can you let me know?
If there is a passage that was not clear or some information that you missed.
Any suggestions for improvement are welcome.
Thanks in advance
Petr
Thanks in advance
Petr
The sampler manual is some kind of confusing. Chapter 4 refers to Chapter 9 and from 9 back to 6 with "brilliant" pictures in it. And so on.
Your manual is quite clear and straight forward. But it doesn't help when "busy" ("bsy" on the sampler screen) means "Fatal Error".
After reading all 122 pages we could find the solution.
Thanks.
Claus
Thanks.
Claus
