Dear sir ,
is there any facility in clarity software that indicates the peak saturation in result table .
saturated peak marks in result table
Sunil Jadhav
Re: saturated peak marks in result table
Dear Sunil,
can you please describe in more details what is your application and what is the desired effect? Without further information, I am unable to come up with the solution.
Dear sir ,
Our one customer is using the TOGA GC with auosampler & Clarity software .
They run the sequance of 40 vials in that there some componant peak height is goes to saturation ( above 1200 mv ) & they have raised following point:
1) When the height of peak goes above 1200 mV ,then in the result table it should be highlighted and also should mention that the peak is saturated.
Thanks & regards
sunil jadhav
Thanks & regards
sunil jadhav
Sunil Jadhav
Dear Sunil Jadhav,
for this purpose I will reccomend to use the optional SST extension
http://downloads.dataapex.com/documenta ... ns-sst.pdf
which allows you to compare some peak parameters (including Peak Height) with predefined limits and report the Pass/Fail result, eventually perform some additional actions.
Also please check if the peaks are cut by the detector itself or by the A/D board - increasing the range may help in the latter case.
how to combined the rresult of Three channel in NGA
Hi ,
I have one problem
- Our customer having NGA conf Gc with Clarity software Colibrick fourChannel .
so three channel are working with two TCD Detector & one FID after analysis we got three result of each Channel.& customer wants only one result which having three channel result hence please help us how i can combine the the results.
Regards
Sunil Jadhav
Thermofisher Scientific ltd
Nasik india
I have one problem
Regards
Sunil Jadhav
Nasik india
Sunil Jadhav
Dear Sunil,
for this purpose the NGA extension is recomended, it is designed to calculate the calorific values according to the commonly used norms and enables to combine signals from multiple detectors
http://www.dataapex.com/product.php?id= ... ns-nga.php
