Dear Mahmoud,
to answer this I will need to know what these instruments are more precisely. As a basis:
Clarity can control over 300 different instruments. By control we mean that the device is governed from Clarity, which means we can set parameters in Clarity, send method to the device, and read it from there. The list of controlled instruments may be found here.
Clarity can cooperate with other instruments using our A/D converters. This means Clarity can gather the analog data given by detectors, supposing the detector can provide the analog signal on some of its outer contacts. Great majority of the detectors can do that.
Clarity can cooperate with other instruments using the TTL inputs and outputs. This means that Clarity can synchronize itself with other devices, for example autosamplers, providing they have external inputs and/or outputs.
Please let me know the vendor of the instruments you speak about and their types.
Regards, Daniel
