Dear colleagues
Some peaks in my result table have N/A instead of Amount. Peak Type displays error.
I have searched help but did not find what it means.
Can anybody help me?
Thank you in advance
Martin Yetter
N/A in table of results
- Petr Kohutek
- Contact:
Dear Martin
The N/A means not available. It can occur when the calibration curve of the given compound does not pass through origin. Then the response of the detected compound can be in the range where the calibration curve would compute negative Amount. This is of course not possible and so when the result table gets negative value, it will display N/A to warn you.
I have put it into documentation and to the FAQ section on the web. And we will introduce some tool tip or other description into the result table in some future update.
